Intermapper 6.1.5 (Juillet 2017)
Annonce des mises à jour
Messagepar NetWalkerTeam » 22 août 2017 16:23
La nouvelle version 6.1.5 d'Intermapper solution de monitoring réseau est disponible et en téléchargement sur download.Intermapper.eu.
  • The Device Notifiers window now refreshes correctly.
  • OK status notifications without a prior alert
  • Changes to maps and background images are now reflected in the Splunk app.
  • Background images now appear correctly when you print a map.
  • The Splunk app now displays events counts correctly.
  • Printing of the Summary of Notifcations in the Splunk app has been improved.
  • The Splunk app Devices menu has been removed from the Splunk app. All access to devices is available from the Device List page.
  • When Devices are associated with multiple probes, the Splunk app's Device List page now shows the status of each of the device's probes correctly.
  • Notifications in the Splunk app are now in sync with Intermapper notifications.
  • Intermapper now installs a more secure version of Java 8 Runtime Environment.
  • When starting Intermapper Datacenter on a new installation, the database is created correctly on all platforms.
  • Intermapper Flows server now starts properly after installation on all platforms.
  • The Flows window can now be closed after the Flows server has been stopped.
  • An issue with opening Link Notifiers View on certain maps in Intermapper Remote Access has been fixed.
  • The Splunk app no longer shows devices from the Detection Map.
  • An issue with sorting in the Device Notifiers view has been fixed.
  • Flows window is now disabled when the Flows Server is stopped.
  • Apostrophes in device names are now supported fully.
  • The Device Notifier view now works properly with the Detection Map.
  • To eliminate confusion, the Detection Map is no longer available through the Intermapper Web Server.
  • Probe groups now save changes properly when in Device Notifier view.
  • Delay and Repeat setting in Device Notifiers view are now saved correctly.
  • The specified default map (if it exists) is now displayed correctly in Splunk.
Suivez nos derniers billets sur le Blog Monitoring Réseau & Serveur avec InterMapper
Retourner vers « Versions »
