Intermapper 6.1.4 (Mai 2017)
Annonce des mises à jour
Messagepar NetWalkerTeam » 22 août 2017 16:21
La nouvelle version 6.1.4 d'Intermapper solution de monitoring réseau est disponible et en téléchargement sur download.Intermapper.eu.
Liste des corrections :
  • [BUG FIX] In Device Notifiers view, the 'Count' column value now updates properly.
  • [BUG FIX] The Device Status icon in List View and Device Notifiers View is now updating properly.
  • [BUG FIX] Controls in Link Notifiers view update properly when the same map is edited by a different client.
  • [BUG FIX] Status is displayed correctly for all maps in Map List.
  • [BUG FIX] When a notifier delay has not been reached, preventing other alerts from being sent, OK notifications are also not sent.
  • [BUG FIX] InterMapper now sends SMS notifiers properly.
  • [BUG FIX] Device notifier listing in Device Notifiers context menu now displays properly.
  • [BUG FIX] When viewing only certain interfaces on a map, the hidden and shown interfaces now remain selected.
  • [BUG FIX] Intermapper no longer sends false ping probe notifications when running on OS X 10.12.1 Sierra.
    [FEATURE] A new logging mode, activated through Telnet, has been added to support web security penetration testing. For more information see the Knowledgebase article, “Activating Web Security Logging”.
  • [BUG FIX] Flows processing now supports 32-bit interface IDs. Indexes in the Interfaces window and the Flows window now match.
  • [BUG FIX] When you right-click a link and view the Interface Notifier window, selections are now saved properly.
  • [BUG FIX] Restoring a map from a scheduled backup now works properly.
  • [BUG FIX] A problem with dropped client connections has been fixed.
  • [BUG FIX] When target server uses Server Name Indication (SNI), HTTPS Probe now connects properly.
  • [BUG FIX] A problem preventing display of the scroll bar in Link Notifier view has been fixed.
  • [BUG FIX] The Detection Map now opens properly after upgrade to 6.1.4
  • [BUG FIX] When attempting to save an Intermapper Flows report to a location for which the user doesn't have access permissions, a more informative error message appears.
  • [BUG FIX] Removed an incorrect error message about hiding of links.
  • [BUG FIX] NPE: com.dartware.util.INDEXABLE_OBJECT$HashSortedList.getInsertPosition
  • [BUG FIX] Viewing a chart from the web UI no longer causes the service to stop.
Retourner vers « Versions »
